Re: Toilet Flange
Posted by Sylvan Tieger on May 15, 2004 at 22:30:26:
In response to Re: Toilet Flange
: I need to close off an old cast iron toilet flange without tearing up the floor. Can someone up?
1- Either solder on a cap
2- If it is PVC or CI or Galv use a no hub cap
3- put some news paper in the pipe about 4" deep and fill with cement or plaster
4- Ping the lead over solder the folded edges so your now water and gas tight << Correct Job
The one above number 4 is easy cheap FIX much like an AAV installation used by infamous BBC's looking to get over folks
Replies to this post
