| Posted by hj on May 14, 2004 at 23:25:04: | |
| In response to Re: Rerouting Plumbing Installation Under Concrete Slab | |
Moving the drain lines is fairly easy and straight forward. Moving the water lines, if they are also in the slab, can be a problem since it is never a good idea to have joints under the slab, even if they are brazed, (and in my opinion especially if they are brazed). : During the construction of my new home, the builder has discovered that all the plumbing installations for appliances, bath tubs, utility sink, washing machine,etc., were not positioned correctly. The plumber is currently jack hammering the concrete slab to correct all incorrectly positioned plumbing runs and outlets. What should I look for during this repair stage? : The builder claims that all will look like new once the repairs are completed. The plumber told me that the concrete holes for access to the bathtub drains and plumbing will be filled with tar to prevent termites from getting through the slab. Everywhere else, he will install rebar and pour concrete to fill all the openings again. Are these repairs placing me in any danger and should the plumbing system work without problems if repairs are made as I am told? The plumber has manifolded the washing machine water drain with the utility sink's water drain. Will this cause any problems? :
| There are none. |
