| Posted by hj on May 14, 2004 at 23:15:23: | |
| In response to Re: sink supply lines | |
Are you sure it was stainless steel. There is a plastic braided one that looks like the stainless steel ones. If it was stainless and broke in the middle, the probability is that it was damaged before installing it. : What are the best supply lines to use to go from the cutoff valve to the faucet. I always thought it was the ones that are wrapped with the steel braid, but I just had one of those burst right in the middle. Are the ones with the nylon braid embedded in the plastic tubing better?
| There are none. |
