| Posted by Vince on May 14, 2004 at 20:14:08: | |
| In response to Re: Hot Water Heater Venting | |
Yes...with qualifications The chimney needs to be lined. The new water heater burn more efficently and will cause condensation in the chimney. Unlined chimney means wet wall inside structure, which are bad. Moisture will travel through old motar. |
| There are none. |
