| Posted by PW on May 14, 2004 at 15:13:29: | |
| In response to Re: keep pipes from freezing | |
Steve, Depends on your crawl space. If you have a heater there you may have enough heat, then again.... Heat tape and wrapping with insulation are probably your best bet. There is heat tape available which is self adjusting, in that a thermistat is not required, which works fine. We us it around our freezer (temps of -10F)where we want to keep pipes warm. : I am adding a bathroom over an existing crawl space. What is the best way to prevent these pipes from freezing in the cold Wisconsin climate?
| There are none. |
