| Posted by Deb on May 14, 2004 at 11:02:35: | |
| In response to Re: Basement floor rough-ins in wrong location | |
: Hello, : I'm in the process of laying out my unfinished basement. The plumbing roughs that exist are highlighted in my example image. The main stack is to the bottom right of the image. : My question is, without ripping the floor up, is it possible to achieve the layout as I've shown it here? Could I build a small step-up to allow the existing rough-ins to be connected to the fixtures as I've shown them? : Or am I best to get the floor ripped up and the rough-ins re-run? I'd rather not do that because I'm sure it would cost quite a bit. : Thanks in advance! I don't see any other way to do this other than to remove the concrete and start over. You are not even close to the original rough in. The toilet needs a 3" drainage line. The lav may be able to be wet vented. You have no drainage lines in the area of the tub, so you would need to run a line over (and make sure you vent it). |
| There are none. |
