| Posted by Deb on May 13, 2004 at 11:15:40: | |
| In response to Re: removing tub | |
: 75 years old need help! replacing tub with shower.metal covered tub. I've taken all the screws out. : how do i remove the drain pipe? tub is in 1974 house trailer. : thank you You are most likely going to need some help. Tubs use a 1-1/2" drainage line and the drain is at the end of the tub. Showers need a 2" drainage line and the drain is in the center. I would recommend climbing under the trailer and cutting the drain from under there since the drainage is going to need to be redone anyway. |
| There are none. |
