| Posted by Jennifer on May 13, 2004 at 01:07:11: | |
| In response to Re: American Standard Smart Valve 2000 problems | |
I'm having the same problem... did you ever resolve this? Did you replace it altogether or just fix it somehow? ~JW : I am having problems with the water fill timing on my toilet. It uses a Smart Valve 2000 fill valve, and it won't shut off when the water level reaches the top of the tank. Once the toilet is flushed, it will run (and the water will fun into the overflow tube) for about 2 or 3 minutes, and then it will (finally) shut off. Is there any way to adjust these "smart" valves or has it just gone bad? Thanks in advance for the help
| There are none. |
