| Posted by Edward on May 11, 2004 at 17:26:29: | |
| In response to Re: Toilet flange height with Toto Uni adapter | |
Terry, Many thanks, when I first installed them (with the old floor below the flange) I felt there was considerable squish with the adapters which made me think I would be ok. : : I am refinishing our bathroom floor and expect the finished floor be about the same height as (or possibly 1/8" at most lower than) the cast iron toilet flange installed in concrete. I'll be reinstalling one of the Toto Uni adapters, would you suspect I will be ok with a #10 wax seal? : Should be. You will want the wax to squish some. You can hold the wax up to the adapter to see if there is some squish room.
| There are none. |
