Re: well pressure and X-Trol
Posted by Alex C. on May 11, 2004 at 11:38:55:
In response to Re: well pressure and X-Trol
: I had my jet pump replaced but the new pump has a pressure setting of 30-50 and my xtrol is set to 18psi. Is there any problems with leaving it this way or should I adjust it 28psi. With the X-trol at 18psi, could this explain why I get a big difference in pressure from pressure full to the pump turning on.
: Thanks
Reply: Thanks for the info, I will adjust it tonight when I get home from work.
Thanks again
Alex
Replies to this post
There are none.
