| Posted by Deb on May 11, 2004 at 11:04:26: | |
| In response to Re: well pressure and X-Trol | |
: I had my jet pump replaced but the new pump has a pressure setting of 30-50 and my xtrol is set to 18psi. Is there any problems with leaving it this way or should I adjust it 28psi. With the X-trol at 18psi, could this explain why I get a big difference in pressure from pressure full to the pump turning on. : Thanks It is not okay to leave it at 18#s. Drain the water from the tank and adjust to 28#s. |
| There are none. |
