Re: Toto Drake toilet product review
Posted by Ronald Clough on May 10, 2004 at 14:38:07:
In response to Re: Toto Drake toilet product review
This is a great toilet flushing system. However, when I took delivery of two Drake toilets from a local supplier, I installed both, and found both tanks leaked. The problem was easily corrected by removing the flush valve assembly, sanding down the surfaces ( both inside and outside the tank) where the large plastic nut comes in contact with thetank, then applying silicon grease allowing the plastic nut to be tightened sufficiently to compress the rubber o-ring gasket enough to make it water tight. The factory should have done this before shipping the toilets. Aside from all that, the Toto Drake is the best flushing toilet I have ever seen. I need two more for another house and will buy Totos. Sanding where the bolts drop through is a good idea too.
Replies to this post
There are none. |
