| Posted by Sylvan Tieger on May 08, 2004 at 11:33:29: | |
| In response to Re: Hot water heater leaking | |
: My hot water heater is leaking, not through the relief valve pipe but through the tank drain fixture. Is there a washer on these that can be replaced? If this tank is older then 10 years you maywant to consider replacing it |
| There are none. |
