| Posted by Vince on May 07, 2004 at 16:54:17: | |
| In response to Re: cracked frost-free sillcock | |
Should of had someone who knows what they are doing install an access for the sillcock when you remodeled. This happened because the sill cock was tilted downward slightly so water would drain out of it. If put in level or tilted upward ever so slightly, it will hold water, freeze, and split just as you decribed. Far easier to fix from the inside, but hey, it's your siding... |
| There are none. |
