Re: Toilet Causes Water Hammer
Posted by Terry Love on May 07, 2004 at 12:59:39:
In response to Re: Toilet Causes Water Hammer
This may work for you.
You could also might be able to install the Korky Quiet Fill valve. They are good at reducing water hammer.
Terry Love
: I read your response to a previous post about installing a water hammer arrestor between the shut-off valve and the toilet, which is also causing me the same problem. You responded that this should be fine, but I am having a tough time locating (on the web or locally) an arrestor sold retail that will fit between the compression thread of the shut-off valve and the larger thread at the intake of the toilet. Would you point me to a source for such an arrestor?
Replies to this post
There are none.
