Re: Hot Mopping a shower - is it necessary?
Posted by Sylvan Tieger on May 06, 2004 at 19:53:55:
In response to Re: Hot Mopping a shower - is it necessary?
: OK - we have a remodel going on and the concrete subfloor around the shower is being broken up - we plan on tiling the entire shower, floor and all. The term hot mop has been bandied about - is it necessary? Can't I buy a reasonable equivalent at Home Depot to seal the concrete, or can I use green board? Aaaargh! Thank you!
When we install a lead pan on bare concrete we use bitumen either hot or cold applied depending on ventilation to prevent moisture from getting between the lead and concrete/wood flooring.
Sometimes this is the term used as "hot mopping" you can possibly use flashing cement as a damp proofing agent.
Replies to this post
There are none.
