Re: My complicated DWH system...
Posted by Jacob Boles on May 06, 2004 at 14:16:34:
In response to Re: My complicated DWH system...
Would this work as the controller:
With a 24V power supply through the switch on the above controller and to this valve:
The prices on ebay for these items are quite cheap.
: : Do these valves open/close based on temperature? Could you point me to an exact valve. I can't find anything in the link you gave me.
: You use controller with a temerature sensor that you attach to the line you want to monitor. How you attach the sensor depends on the type you buy. It could be a surface mount or immersion probe. Depends on how much you want to spend, how large the system, and how critical is the accuracy of the probe.
: My thoughts for you, provided you want to do this yourself, is to go to a HVAC supplier like Johnstone. They would have everything you would possibly want for this system.
: Go to this site for a location near you.
Replies to this post
There are none.
