| Posted by hj on May 06, 2004 at 09:18:44: | |
| In response to Re: Quick Vent - Air Admittance Valve | |
If you install AAV's on all the fixtures, including the ejector basin, you will create a sealed system and nothing will drain because the AAV's will not allow air to escape so water can displace it. : I am installing a bathroom in my basement. A plumber recommended a 'quick vent'. I assume that this is an air admittance valve. : Can the ejector pump be tied in to one of these valves? : Thanks for the help.
| There are none. |
