| Posted by Richard on May 05, 2004 at 18:59:36: | |
I have a Culligan Mark 89 water softener which has a constant, low-volume flow through the tube that leads to the street that usually sends a good deal more volume when it runs through it's normal cycle (usually at night). The bypass switch has turned off the flow. The clock is set correctly and is keeping time. Because of that and the low flow coming out of the tube, I don't think it's stuck in the normal flush cycle. Could this be a sensor problem of some sort? |
