| Posted by Hube on May 05, 2004 at 18:13:43: | |
| In response to Re: Replaced well pump - Debris coming out of the faucets | |
: Hi all, : A well repair guy replaced our well pump (a 1994 Goulds pump) Two days ago. : He and his assistant used some kind of apparatus with three wheels to pull the pump out. They said the axle inside the pump was not turning. They put in a new Goulds pump of the same size and water problem solved BUT now there is quite a bit of debris (mainly bits of leaves, pine needles and sand) coming out of the faucets. : Is this normal? (When they pulled the pump out, about 200 ft of black house had to lie on the ground while they replace the pump). These people poured 1 gallon of household bleach in the well and told us not to drink the water for 24 hours. : Our water used to be better than spring water, now I don't know if we'll ever get pure, uncontaminated water from our well again. : My question: Do all well contractors lie the black house on the ground? Do they just clean it with a rag as it goes back in the well and that's that? : Thanks for any advice, : ST |
