| Posted by Alex on May 05, 2004 at 11:02:55: | |
| In response to Re: Jet pump power supply question | |
Reply: I have enough 220 wire and a spare breaker left over from an upgrade last month. I'll switch it over this weekend then. With our hydro rate change this month, less electricity the better. Thanks for the reply. Alex : : 1. You can use smaller gauge wiring due to the lower current; : 2. Most motors which are dual voltage design will run with greater overall energy efficiency if run at 220, thus a savings on your electric bill.
| There are none. |
