Re: Finally called 3 plumbers
Posted by Gary Swart on May 05, 2004 at 01:19:52:
In response to Re: Finally called 3 plumbers
The 2" might be OK, but why not go with at least 3"? Unless there is something you posted earlier about a space problem, it just doesn't make much sense to push the drain capacity to the limit. Labor would be essentially the same to install 3" and materials are not that much difference either.
Replies to this post
