Re: Should toilet drain pipe be replaced? - Update and Thanks
Posted by e-plumber on May 04, 2004 at 15:28:28:
In response to Re: Should toilet drain pipe be replaced? - Update and Thanks
: Hi everyone:
: A week ago or so I asked some questions regarding fixing the cast iron drain for my toilet. After reading the answers from this site, I decided it was a job for a pro.
: I'm so glad I went that direction. The plumber was able to save all the cast iron pipe, replacing only the flange, and re-sealing the join in the basement. This was a repair I couldn't possibly have done myself, as I simply don't have the tools or knowledge to work with lead.
: While we were at it, we decided to replace the old toilet (original 1964 high flow) with a Toto Drake. So far, we're very happy.
: Thanks to all who responded to my posts!
: -A little poorer, but with a working toilet, in Michigan
Reply:
At least you knew when to draw the line between a DIY job and when to call in a pro. Better off this way then to get knee deep, then have to make the call.
e-plumber
Replies to this post
There are none.
