Re: Wash machine dual shut-off valve
Posted by hj on May 04, 2004 at 09:11:52:
In response to Re: Wash machine dual shut-off valve
If you use them frequently, they will eventually start leaking, like any other valve. The advantage is that the working portion is held by bolts so a new one can be easily attached to replace the bad one.
: I am wondering if anybody has had or seen any problems with a washing machine dual shut-off valve. I will be installing new plumbing in a couple months and wanted to know if I should use that or go with two separate valves. Thanks much! Richard
Replies to this post
There are none.
