leaking shut off valve
Posted by Jerry on May 03, 2004 at 14:29:29:
My son has tried several times to fix the leak at the shut off valve located near his hot water tank. This is not the valve for the hot water feed. This is the incoming feed for the whole house. We tried to replace the velve with a new one,but it still leaks. We used PVC pipe cleaner and cement on the repair without any results. Could you please help? Thank you.
Replies to this post
