Re: Water Pressure, & Wells
Posted by Paulette on May 02, 2004 at 11:29:47:
In response to Re: Water Pressure, & Wells
One thing I would recommend against is resetting your pressure without knowing any information about your well and pumping system. It is very possible that your well and/or pump are already providing pressure and volume at their maximum performance. So although Hube is technically correct in describing the method of how to reset the pressure switch and inflating your tank to the proper air pressure, the question remains can you current well and pump handle the raise in delivery pressure? Do you have any records available to you about your well and pump?
Replies to this post
