Re: Water Tank Pressure
Posted by Hube on April 30, 2004 at 18:00:32:
In response to Re: Water Tank Pressure
: How do i pressurize a wter tank? I changed the pressure switch and now the pressure goes up and down everytime i turn the water on. Thanks
Drain the pressure tank of water. The air psi within the tank should be 2 psi below the pumps cut-in setting. Use a bike (or similar) type air pump. Post back if you need additional info on settings,etc....Hube
Replies to this post
There are none.
