Re: high temp thermostat circuit breaker
Posted by hj on April 29, 2004 at 00:05:26:
In response to Re: high temp thermostat circuit breaker
It will normally only operate when it is supposed to. You more than likely have a water heater that needs service of some kind.
: My high temp thermostat circuit breaker continually kicks out and has to be reset every couple of days. Can this thermostat(s) be changed out on this water heater? It is a Reliance 501 model w/two 4500 heating elements. Do you carry these parts if applicable? Thanks in advance for your reply..CR
Replies to this post
There are none.
