Re: Basement plumbing
Posted by ED on April 28, 2004 at 15:45:48:
In response to Re: Basement plumbing
Not much work to install an offset toilet flange.
(If you have not enclosed pipes in slab)
ABout 4 inches on the side of the offset a bit less on the opposite side.
Did you use a 4 inch pipe for the run from the flange and then a 4X3 closet bend?
You can use a inside cutting wheel to cut the pipe if it's encased in concrete.
: : Did you use two inch pipe for drainage?
: -Sure did
: :Did you use a P-trap?
: -Yes but it is about a foot away from directly under the drain opening
: :Is this fixture vented? How?
: -Yes tied into the the lavatory dwv
: : SOunds like it was a rough rough-in.
: : 10" from unfinished wall is EXTREMELY TIGHT for a flange, but it might be possible. You could consider using an offset flange which will give you about two more inches.
: - Ah great more slab work! How far into the slab do you generally have to go for an offset flange?
: : You can space the cans every four to five feet. People tend to like a well-lit bath. You should also have lighting over the vanity and perhaps over the shower. If you install lighting directly over a shower or light-fan combo, it must be protected with a GFI circuit.
: - Good point - thanks Ed!
: : : I am finishing my basement with a full bath. Rough ins were rather "rough" and some slab work required for the shower drain. I have relocated the shower drain 1' 6" and it turns out that the last fitting, a 90 deg sweep, will be partly sealed in the concrete slab when finished. Also it ended up slightly out of vertical, a little less than 1/4" over 1' (take a guess why!). I'm planning on an inexpensive 48" pan. Could these be significant problems?
: : : Another issue is that the center of the toilet flange is 10" from the unfinished wall. Are the 10" rough in toilets forgiving enough to allow for 1/2" of drywall?
: : : Finally what is the recommended spacing of 6" recessed lights in an 8' ceiling? Space is about 20'x10'.
: : : Thank you!
Replies to this post
There are none.
