| Posted by Dave V on April 27, 2004 at 21:25:20: | |
| In response to Re: Basement plumbing | |
: Did you use two inch pipe for drainage? -Sure did :Did you use a P-trap? -Yes but it is about a foot away from directly under the drain opening :Is this fixture vented? How? -Yes tied into the the lavatory dwv : SOunds like it was a rough rough-in. - Ah great more slab work! How far into the slab do you generally have to go for an offset flange? : You can space the cans every four to five feet. People tend to like a well-lit bath. You should also have lighting over the vanity and perhaps over the shower. If you install lighting directly over a shower or light-fan combo, it must be protected with a GFI circuit. - Good point - thanks Ed! : : Another issue is that the center of the toilet flange is 10" from the unfinished wall. Are the 10" rough in toilets forgiving enough to allow for 1/2" of drywall? : : Finally what is the recommended spacing of 6" recessed lights in an 8' ceiling? Space is about 20'x10'. : : Thank you!
