| Posted by ED on April 27, 2004 at 16:40:18: | |
| In response to Re: Basement plumbing | |
Did you use two inch pipe for drainage? Did you use a P-trap? Is this fixture vented? How? SOunds like it was a rough rough-in. 10" from unfinished wall is EXTREMELY TIGHT for a flange, but it might be possible. You could consider using an offset flange which will give you about two more inches. You can space the cans every four to five feet. People tend to like a well-lit bath. You should also have lighting over the vanity and perhaps over the shower. If you install lighting directly over a shower or light-fan combo, it must be protected with a GFI circuit.
: Another issue is that the center of the toilet flange is 10" from the unfinished wall. Are the 10" rough in toilets forgiving enough to allow for 1/2" of drywall? : Finally what is the recommended spacing of 6" recessed lights in an 8' ceiling? Space is about 20'x10'. : Thank you!
