 : I recently drained the radiator system when I removed : one of the radiators in a downstairs room. : I then released the cold water tap to top the water upto the 1.5 bar mark and turned the system back on. : However water started shooting out from the air vent cap above the pump in my Valiant boiler. : I thought the problem had been resolved when I tightened the cap but I still have a small leak coming : from this cap. : Please can you advise what I have done wrong and if I can resolve. Reply: If it's a float type automatic vent with a Schrader valve on top, you may need to replace it. e-plumber
