| Posted by hj on April 26, 2004 at 23:15:58: | |
| In response to Re: Bath tub needs special waste shoe | |
The old shoe was probably the "short" pattern and most of the new ones are a long pattern which changes the distance to the center of the pipe. I had to change one recently and was fortunate to have one left over from a job done years ago. : We are remodeling a bathroom for a house built in '62. Since we purchased a few years ago, the old tub waste shoe never drained empty--there was always water standing in the shoe. I am replacing the bath plumbing but have found when I install the new waste shoe, the bottom of the tube at the shoe outlet is about 3/8" higher than the bottom of the tube at drain attachment. So if I install the new equipment, I will still have water standing in the shoe. The tub is reasonably level, if anything settled down slightly to the plumbed end. From the crawl, I can put a level against the bath drain opening and it does tilt up toward the front. The only thing I can imagine is that there must have been a waste shoe available at one time that was angled for the angled tub attachment and, if mounted on a standard tub, it would have angled down and away. This was replaced at some time by a standard shoe and there has been trouble since. Aside from casting a wedge shaped washer out of silicone, which I am trying to do, can anyone offer suggestions for a product or solution?
| There are none. |
