Re: Hot water heater dripping
Posted by hj on April 26, 2004 at 23:13:34:
In response to Re: Hot water heater dripping
If it drips continually then you should replace the T&P valve, as long as the regulator is keeping the water pressure at the proper level.
: Our hot water heater has been dripping water out of the long copper pipe onto the concrete basement floor. The water heater is about 5 years old and so is the Therm-X-Trol expansion tank. I lowered the pressure of the water coming into the house but this did nothing.
: A plumber told me that I probably need to replace the T&P valve on the water heater, or replace the expansion tank. Does this sound correct? The T&P valve is only about $5 at Home Depot but I haven't been able to find a price on the expansion tank.
: Which should I try first?
: Thanks
: Martha
Replies to this post
There are none.
