Re: Need help: washer/dry hook-up in apartment
Posted by Gary Swart on April 26, 2004 at 00:14:03:
In response to Re: Need help: washer/dry hook-up in apartment
It would have been better had you checked on how the hook-ups could be done before you bought, but it's a little encouraging to know that other residents in the complex have W/Ds. Most washers require a 2" standpipe and drain, so a sink hookup usually won't work. It is possible that the unit you have is smaller than a typical washer and perhaps could use a smaller drain. It would seem to me that you should discuss the problem with the owner/manager of the apartments. Can't be more specific without knowing more about the plumbing. If the drains are large enough, you will need to have a plumber make all of the connections. In a rental unit, there are libability issues for a DIY hookup.
Replies to this post
There are none.
