| Posted by Vince on April 25, 2004 at 21:08:20: | |
| In response to Re: Shared Trap | |
: Thanks again for the great info do you have a Master of the Obvious degree? Quite an eyeopener. If you happen to be over 34 years old, then you are older than my master's license. : Codes are setup by faliable humans for the lowest common denominator and are always evolving (never mind be different depending on your jurisdiction). They can never address all situations and often err on the side of excessive caution for the sake of allowing for a wide variety of installations, often non optimal. Here I am more referring to some aspects of HVAC and electrical code that, being within my scope of expertise, I have definitily found to be over engineered. Now all this being said I am quite open to being convinced this is a bad idea. An expert in your field, what a waste of talent. Why aren't you on any boards establishing the code?
| There are none. |
