Re: soft water loop
Posted by hj on April 25, 2004 at 19:59:16:
In response to Re: soft water loop
IF there were a loop it would be obvious since there would be two water lines coming out of the wall with a connection between them. Normally the only things not on the soft water are the outside hose faucets.
: We just moved to Las Vegas, and have heard numerous information regarding putting in a loop in our house & a water softener. I would like to know what it takes to put in a loop. Which part of the house do you not need to connect to the loop. If a house was built in 1989 in the Lakes area, would the loop connection already have been separated from the water meter, would it be possible that the house was already set up for loop plumbing? What water softener system would be best? The ones with the salt or any other ones you could recommend.
: Thank you
Replies to this post
