: replaced flush ball with discontinued substitute and toilet will not shut off
Reply: The exact Kohler replacement part should be used or the equivalent for your Kohler toilet model. The part you installed probably isn't seating correctly on the flush valve causing the fill valve to run non-stop. e-plumber
