| Posted by chunster on April 24, 2004 at 22:57:14: | |
| In response to Re: TOTO ULTRAMAX flooding | |
: It could be two things. : Most of the time, it's a flapper that doesn't seat. : I would check how well that is working. It should open and drop in the same place with no obstruction such as a loose chain. : If the flapper is sealing, then perhaps it is the fill valve that is not sealing off. : Dirt on the seal can sometimes prevent shutoff. : The link below has cleaning instructions. : As far as the paper goes, some of the new 2-ply paper has cotton in addition to the wood fiber. Terry: Thanks very much.Your site is great. What do I do if the flap valve is not sealing properly and how often does it need to be replaced? How do I find out how to clean or replace it? To check if the flap valve is leaking do I put a dye in the water closet and see if the dye makes it into the bowl? Is there a dye I can use that won't stain the inside of the porcelain? |
| There are none. |
