| Posted by jimbo on April 16, 2004 at 10:42:15: | |
| In response to Re: Shower Control Problem | |
: You didn't mention if this is a push-pull type of control, or if you simply turn it to get water and adjust the temp. Depending on the brand and model, if it is a so=-called pressure balanced unit, the balancing spool can get stuck, particularly during a period of non-use. Disassemble , clean, and lubricate. If it not a press. bal. unit, probably some debris has lodged inside the assembly somewhere. Disassemble and clean. |
| There are none. |
