Re: Broken Sillcock Handle
Posted by e-plumber on April 13, 2004 at 18:37:23:
In response to Re: Broken Sillcock Handle
: I recently broke the silcock handle while it was in the open position. I was lucky enough to replace the handle easily. Once I turned the water back on and tried to close the water would not completely shutoff. Is there something that needs to be done to fix the problem. Reply: If the leak started since the handle has broken I would say it has to be related. Did the handle go on correctly, if it wasn't an exact replacement handle for your brand faucet, it could be interfering with the closing mechanism, under the handle. e-plumber
Replies to this post
There are none. |
