| Posted by Hwrd69 on April 13, 2004 at 08:29:03: | |
| In response to Re: Notching Load-bearing Stud | |
Specifically, to the reposnse from ED, what is sistering? : If you have the wall open, you can always sister the notched stud with another notched stud, if it makes you feel more comfortable. : : : : : Thanks for your assistance. : : : A maximum 50 %notch in one stud will NOT create any problem. Only notch in halfway (max).. The wall being attached to this stud will help this stud avoid any deflection. Hube : :
| There are none. |
