changing old galvanized pipes
Posted by Jon on April 13, 2004 at 07:38:13:
This is a multipul part question message.Heres the situation.I have a bathtub,sink and washing machine in a second floor bathroom.I need to run new drains for all 3. Currently the tub is a seperate line and the washer and sink are in the other.Which ones can I run in the same pipe?The existing hub has (2)1 1/2 " taps off the toilet that tie into the soil stack.If I need to replace the toilet hub and flange and existing pipe how do I cut the cast iron stack.It appears to be the original pipe from 1929 and has the lead and oakum seals.Also there is no venting except over at the sink drain.Thanks again Jon
