| Posted by Sylvan Tieger on April 12, 2004 at 12:11:52: | |
| In response to Re: temperature s. pressure | |
: Did some homework regarding previous discussions on this issue. The formula is called the Combined Gas Law. It is a combination of Boyle's Law and Charles' Law. : P1V1/T1 = P2V2/T2 : If we assume constant volume in the pipe, we can leave V out. : Example: Pressure = 15 PSI, temp = 70 degrees. If temp changes to 50, what is the pressure? : 15/70 = P / 50 : P = (50 X 15)/70 : P = 10.7 PSI Thank you Jimbo |
| There are none. |
