Toilet flange install
Posted by john on April 12, 2004 at 09:35:52:
I have remnmove the old flange which was LEaded into the Cast drain pipe. The inside diameter of the drain is 4 1/4 inches. I tried to fit a 4 inch PVC flanfe in the hole with a rubber ring. it was to small. My question is do they make a PVC Flange or larger Rubber ring that will fit this opening. Or, Can you lead a PVC pipe into the cast drain?
Thanks,
JFS
Replies to this post
