Re: water levels in Gerber toilets
Posted by jimbo on April 11, 2004 at 10:54:21:
In response to Re: water levels in Gerber toilets
: The picture posted by e-p. shows clearly that the maximum height of the water level in the bowl is determined by the design of the bowl itself. Even if the refill tube keeps running, the level will remain the same; the excess water just runs over the spillway.
If the water does not reach it's designed level, then you have a problem with the refill system inside the tank.
Replies to this post
There are none.
