Re: Americast "creak" under load
Posted by Paul Brick on April 10, 2004 at 20:15:21:
In response to Re: Americast "creak" under load
To rectify a response to the wrong entry -- Posted by Paul Brick on April 10, 2004 at 19:53:36:
:I rechecked the stringer for level along its length and across its width ... both are good. I made height measurements with and without a jig (built to the manufacturers setup specs) and both approaches verify the setup of the stringer. My conclusion is that there are small imperfection on the underside of the tub where it sits on the stringer. I'm inclined to use Henry 547 underlayment as filler for the small gap between the stringer and the bottom of the tub flange. A few experimental pieces I made seemed to work out OK. If anyone has a better idea (a structural foam?) I'm open to suggestions.
Paul B.
: It may be dead level, parallel, and smooth, but is it at the exact height so that it is supporting the flange but not lifting the tub off the floor?
: : I have installed an Americast Princeton bathtub and find that flex under load at the back wall stringer creates a creaking noise. I confirmed the tub to be level front to back and side to side. The flange of the tub has a small gap (1/6 to 3/32 of an inch) at the drain end when resting on the stringer and the flex noise in that area stops when a small cedar wedge is fitted. I cannot find any other point with a tub flange to stringer gap of any sort.
: : I have removed the tub inspected the stringer and floor and found them to be dead level, parallel and smooth.
: : In preparation for reinstallation, I sanded off the mold selvage along the underside of the tubs flange area but am wondering whether there is any sort of bedding that I might put on the stringer to eliminate gaps and the resultant creaking noise when loaded? I'm concerned that whatever I do needs to be able to support the roughly 700 pound of water that a full tub will hold and have reasonable longevity.
: : Given the large number of these tubs sold I can't believe I'm the only one experiencing this problem.
: : An ideas/suggestions will be appreciated!
: : Paul B.
Replies to this post
There are none.
