| Posted by e-plumber on April 10, 2004 at 14:55:35: | |
| In response to Re: Americast "creak" under load | |
: It's dead-on! I've triple checked it along the length of the tub! Reply: : : It may be dead level, parallel, and smooth, but is it at the exact height so that it is supporting the flange but not lifting the tub off the floor? : : : I have installed an Americast Princeton bathtub and find that flex under load at the back wall stringer creates a creaking noise. I confirmed the tub to be level front to back and side to side. The flange of the tub has a small gap (1/6 to 3/32 of an inch) at the drain end when resting on the stringer and the flex noise in that area stops when a small cedar wedge is fitted. I cannot find any other point with a tub flange to stringer gap of any sort. : : : I have removed the tub inspected the stringer and floor and found them to be dead level, parallel and smooth. : : : In preparation for reinstallation, I sanded off the mold selvage along the underside of the tubs flange area but am wondering whether there is any sort of bedding that I might put on the stringer to eliminate gaps and the resultant creaking noise when loaded? I'm concerned that whatever I do needs to be able to support the roughly 700 pound of water that a full tub will hold and have reasonable longevity. : : : Given the large number of these tubs sold I can't believe I'm the only one experiencing this problem. : : : An ideas/suggestions will be appreciated! : : : Paul B.
