Re: Americast "creak" under load
Posted by hj on April 09, 2004 at 22:46:32:
In response to Re: Americast "creak" under load
It may be dead level, parallel, and smooth, but is it at the exact height so that it is supporting the flange but not lifting the tub off the floor?
: I have installed an Americast Princeton bathtub and find that flex under load at the back wall stringer creates a creaking noise. I confirmed the tub to be level front to back and side to side. The flange of the tub has a small gap (1/6 to 3/32 of an inch) at the drain end when resting on the stringer and the flex noise in that area stops when a small cedar wedge is fitted. I cannot find any other point with a tub flange to stringer gap of any sort.
: I have removed the tub inspected the stringer and floor and found them to be dead level, parallel and smooth.
: In preparation for reinstallation, I sanded off the mold selvage along the underside of the tubs flange area but am wondering whether there is any sort of bedding that I might put on the stringer to eliminate gaps and the resultant creaking noise when loaded? I'm concerned that whatever I do needs to be able to support the roughly 700 pound of water that a full tub will hold and have reasonable longevity.
: Given the large number of these tubs sold I can't believe I'm the only one experiencing this problem.
: An ideas/suggestions will be appreciated!
: Paul B.
Replies to this post
