EXPERIMENTED with Bio-Clean Re: Drain clog fixed, should regular chemicals be used to maintain?
Posted by Peter David on April 08, 2004 at 22:38:04:
In response to EXPERIMENTED with Bio-Clean Re: Drain clog fixed, should regular chemicals be used to maintain?
This morning, I bought Bi0-Clean and I am in the middle of an experiment. I took a wad of hair from a tub drain, hair from a brush, two grains of cooked rice, small piece of chop meat and a small piece of toilet paper. I put it in a container with luke-warm water and about 1/8th teaspoon of Bio-Clean. It has been sitting about 3 hours, so far I see no results. Should I expect everything to breakdown? I will report results. Thank you for all the good advice, I never heard of Jet cleaning, any idea what it costs? Regardless of the cost, I would do it if it helps our system.
Replies to this post
